Don't forget the fine gauge ground wire.
If you use Cardas Litz, the trick to tinning the ends is easy. Place the ends sticking straight up. Then run a solder blob from the tip, down, using gravity. Burns the insulation off and tins the leads. The trick is having the ends pointed straight up and starting the blob at the tip.
