phase linear 400
I used a terminal strip in my 400 S1 after I saw how it simplified the wiring in my 400 S2. Both amps were already built and running for months before going back in and installing the strip.
The thing about Gene's build I'd be concerned about is clearance if he uses meters.
it was a suggestion to route the ac away from the b+voltage corner...
You want all the AC tight in that fuse corner. The rule for AC is short, sweet and always paired with its return. I think those purple wires along the top might be your AC for the light board. If so, that should drop straight down to the floor from the transformer, take an immediate turn to the front panel and run along the front of the chassis to the light board. Get it away from the input sections of the control board.
i have clearance....
they are just tied up out of the way..
as i do not have meters for this unit....the wires will be run to the front before i button it up...the purple is ac for light board...the red/gray are for the meters
i just wired it in advance in case i stumble on some meters....i am pretty sure the other 400 is lost...i had a led board and dcp bought for it ..oh well...
life goes on...
easily done...
thanks again...
i will modify the other wopl too...
as they are wired similarily...
life goes on...
Soon enough Gene...
