- Mar 6, 2022
got the dodge back yesterday....got home...got out closed the doors...was immediately locked out...would not open...even with the key....
we fiddled and fiddled and finally got it open....seems they left out a rod in the drivers door that actuated the electric locks using the key...
found the rod in the bottom of the door...still full of shattered glass...lol
windshield wipers would not turn off...had to pull the fuse...
steering wheel is way off...but the alignment is good....drive hands off...
seems one of the collars that adjusts the steering between the tie rods moved...against the threads...
should not be a big deal...chase the threads....realign...
fluids are good...
no power...
soft shifting...wont downshift...
two codes...referring to the fact the fuel guage isnt working...p0462 and p0463...
guess i need to get under and start looking for cable/wiring damage....need to clean and grease anyway...
would not restart...had to remove the pke system...and revert back to stock key....seems when i exited the capsized truck...i must have stepped on the start button...it was pretty much busted....
anyway...got the locks worked out...and now it cranks...ordered a new start switch for the pke...
probably go to the mechanic tomorrow...and start sorting this out one by one...
the body shop did a magnificant job...the truck looks brand new...
and more good news....
my debit card arrived today....whoopie!!!!
i can breathe again...lololol
fluids are good...
no power...
