dcp engaging...blue led lights when engaged ...right channel bias set...left side unresponsive....b+- voltage presentAlso, is your relay still clicking and the contacts are clearly not welded? Additional fuses, bias transistors. No visible swelling or leakage of any electrolytic caps?
i am open to suggestions and recommendations...Gene, while your at it consider getting a good Fluke meter and installing all the upgrades to the amp like feet and Phoenix Contacts on the backplanes. The Phoenix Contact part#s are at the end of the control board BOM PDF. Just saying, consider it. May as well at this point.
If you get a meter ask the guys for recommended model #s. My Flukes are older US Govt. NSN models made for general use, model# 77 B/N. Better are available.
not welded..functioning...bias transistors tested good....i went through all...when i got different readings from left and right...i removed from circuit to confirm...Also, is your relay still clicking and the contacts are clearly not welded? Additional fuses, bias transistors. No visible swelling or leakage of any electrolytic caps?
I have 2 and make sure you get one w the Case. They don't need calibration for what we do and they are very accurate . The Fluke 77 has a better case than the newer ones do. How many Resistors are bad?that model 77 sure likes the same exact unit i had in the early to mid 80s....
they are cheap on ebay....
do they ever need calibrating...if so...can i do it??
I use a Fluke 77 and an 89............... They are awesome. Spend a few extra bucks and don't scrimp on test equipment. When you rely on them to troubleshoot all your stuff, $150 is cheap. Cheaper meters will give you cheaper results.
https://www.ebay.com/itm/134202867454?epid=1824522723&hash=item1f3f1d3efe:g:Ji4AAOSwrKNi~aHm&amdata=enc:AQAHAAAAoI8wh1MW/WkxoAjt9LN1crcJOmzTaMFCAgdnlDblQ7lNGp5/HEwbqYiOvPC3Rlp/R/A2ZjKL8oaN1ad8sBcESquneegyD387MWSKMJD6gaR+4RV0ss9CFIEZ7lWwyS7uq1au+1SAAPSr8LKPZh13N+ZPPRBXQTI7t2Ja9Cw64kwfhCCUb/QuA6vkcIeuJZwWie7DWPJOZltm6oRnq5sCvek=|tkp:Bk9SR-bEicbbYA
Gene, if you splurge for a Fluke, get the case/holster and ORIGINAL leads. The 77 B/N manual describes calibration, but one needs the proper calibrated voltage source, very expensive, so I've never pursued it or felt the need.
The 77 B/N were produced specially for the Federal Government and were very common in all military maintenance shops I worked in.
If I was buying my first Fluke, I'd shoot for something newer than a old B/N.
All the aftermarket miniclip leads and such fit perfect.
Might want to double check , you should have 3 Emitter Resistors .33 Ohmsv77...i really dont want to spend over 100..
4 emitter resistors and r1 and r3...
r3 bad powder burn under it ...it wiped off...but its definitely zapped..
all of this over a tiny line of solder i evidently left on the face down faceplate...
