- Mar 6, 2022
ok...as instructed....
both 10 ohm resistors are good....both 150 ohm resistors are good on left back plane
no inputs connected....no speaker outputs connected....
right channel is fully populated with the new transistors i just got from joe....left channel transistors checked and rechecked...4 were bad...tossed
left channel has the bottom row populated only....2 checked transistors in the bottom row on the left channel....i checked 95/96 location...all is correct...with them alternating with 96 closest to the transformer....
all fuses good 2 on back plane 2 on chassis on left side...and the main ac fuse also good...
dcprotect relay engaged....i watched the reeds....and the blue led lit after a few seconds...i watched the relay disengage when i powered down...and the blue led went out...
the relay is not welded....it is functioning properly....
b+ is +82.4 and b- is -82.4 on the back planes test points...both sides
+- 15v test points on control board are +- 15v...both sides
the left bias is 13 to 14 mv and does not respond to bias adjustment...
right bias is 365...as i set it the other day....still exactly where i left it...midway the recommendation of 350 to 380mv...
dbt bright then dim as expected....
meters lit....no response from needles upon relay engage...nor disengage
after the testing...i rechecked all fuses....they are fine...
i did NOT reinstall the legs i removed to confirm the bad emitter resistors and r1 and r3....
