- Mar 6, 2022
go george go!!!
			in louisiana they are called nutrias...lolHey Gene,
Just a bit off topic as tends to happen,
Do you have any capybaras down your way ?
Joe does an amazing job kitting the parts for his WOAD offerings. When I was 15, I was building Heathkits, PAIA, SWTPC, Dynacos ... etc.. Sadly those are all gone now, but we get to relive some of that when rebuilding WOPLs. Makes you want to go to ebay and buy a bunch of PLs and make them all into WOPLs !Build is going good he finished soldering the wires to the backplane boards. The boy is really enjoying this project. It's sad that his peers haven't got a clue or any interest. Will be updating with pics when I get a chance.
Yes I'm greatful for Joe and the whiteoak team for providing these Kits. It's awesome to have the PL past down generations. I know what you mean about buying more PLs. I've been dreaming about a PL700.Joe does an amazing job kitting the parts for his WOAD offerings. When I was 15, I was building Heathkits, PAIA, SWTPC, Dynacos ... etc.. Sadly those are all gone now, but we get to relive some of that when rebuilding WOPLs. Makes you want to go to ebay and buy a bunch of PLs and make them all into WOPLs !
as per georges suggestion...i added an ac terminal strip to help seperate ac from dc...and ran a new wire...really neatened it up!!Okay so do I splice the wire from the thermo control to route it on the edge? On a side note I replaced the power cord.
As close to the backplane as practical George and Peter.When I built my 400s, best practice was to run the AC up and over the fuse holders, across the top, then down to the thermo breaker, keeping that AC away from the boards.
Evidently Joe gets lower noise numbers taking it straight across. Very similar to the AC leg on the 700s.
Joe, do you keep the run tight against the backplane board, or pull it out equidistant between the backplane and control board?
