Newly assemble pl14 rev G bias trimmers do not work correctly
#22
Don't doubt it. I searched my shit and never found anything close....I hope i told ya that...
#23
Sorry to sound dumb, are the rail fuses the screw in fuses on the back? I never removed those. The amp was working after the DC and cap install. Does the copper bus bar between the large caps connect the caps + on bottom cap to - on top cap? I replaced the new ones the same direction the old ones came out. I did cut off the other white wire and remove from PAD5R. See pics, still -.019 on the test points. No trimmer adjustment. View attachment 66517 View attachment 66518 View attachment 66519 View attachment 66520
Yep, PS caps are in right. Yes, rail fuses are the screw in type on the back.
Minnesota
#24
your wiring not right , This is a Full-comp ????? I just did one and All my wires are hooked up for both boards Your PNP is not wied and is wired to the wrong spot & needs to be wired to the correct spot , you have no power for you Rt Control board 11,12
I would not hook up power yet, I will find mine wiring notes and post them
CrazyIvan
#29
Soooo...the output stage is full comp also...don't get insulted bud, just makin sure...whatcha got for outputs?
I am not insulted, I am new to this. I didnt know which way to build the board, full or quasi, I chose full. Im not sure how to answer what the output stage is.
#32
If the amp is in quasi configuration .....Houston, we have a problem. post a pic of the outputs, so we can tell if ity's a full or quasi, I'm betting quasi...
C7 on the DCP board looks like it's in backwards as Perry has noted. A close up pic of that would be nice... too
#33
Ivan, the DCP is the board from WattsAbundant for speaker protection. Who built it? Check C7 for backwardness insertedness
#36
Ivan, you have a early 400 that was built with a quasi complementary point to point wired back wall, then the output transistors where selected and installed specifically for that quasi complementary back wall.
If you've not modified the back wall by rebuilding it full comp and installed the different output transistor configuration, then you need to build the control board quasi complementary to match it.
Also check your fuses for correct type and value. Some of these amps have had automotive fuses from the old Pontiac behind the barn or straight pieces of heavy copper wire.
Ask any question and we'll try to help. Nice job on the board!
