- Mar 6, 2022
yupi have these....is 4148 the same as 1n4148....they look the same as the one i removed...
god....i am sure that i did....and i can never express my gratitude....Good, you wore us out
i try to buy a little extra when i order stuff....i have actually used several of these and a bunch of the box of resistors....
fishinggod....i am sure that i did....and i can never express my gratitude....
i laughed when i read your post....maria asked why i was laughing...
i explained how tired you were from helping me....of course she joined in...
i cant express enough my gratitude....thank each and every one of you....
what happened to laatsch with second a silent???
have not heard from him in days????
get arrested??
need bail money??
I guess all the weak components died , (Gene did not want them in their) I think they started out wrong ,, weeks ago . I tried steering it back from the ground up,, I think this Funny looking board has better traces than the 400 II and 700 II wow every time I go in their,, Wire fall off and some times after unsoldering components the traces lift up LOL every time I flip the board back up I look for broken wires.Sure, either that or bug out all the fried components...
I like to use a Tooth brush and I brush everything its amazing the stuff that you can't see that fall out but the fallen solder can the hardest to see and shorts derive out. Also look at the front of the board for anything that also fall in-between stuff and also look at the last output transistor (all) for more fallen solder.
Gene you said that Yesterday and you were up late ,
Here the pic everything is checked out expect the Full Comp parts vs the Q
its installed....and of course tested in circuit...
fishing
Nicely assembled. Your nuts are on the wrong sideI guess all the weak components died , (Gene did not want them in their) I think they started out wrong ,, weeks ago . I tried steering it back from the ground up,, I think this Funny looking board has better traces than the 400 II and 700 II wow every time I go in their,, Wire fall off and some times after unsoldering components the traces lift up LOL every time I flip the board back up I look for broken wires.
backplane????I guess all the weak components died , (Gene did not want them in their) I think they started out wrong ,, weeks ago . I tried steering it back from the ground up,, I think this Funny looking board has better traces than the 400 II and 700 II wow every time I go in their,, Wire fall off and some times after unsoldering components the traces lift up LOL every time I flip the board back up I look for broken wires.
on the transistors in the heat sinks????Nicely assembled. Your nuts are on the wrong side
Yes for serious pros...I thought about soldering your nuts in place Gene but then figured we would not have another 83 pages...backplane????
i read that is the tough one...
gotta learn...better sooner tgan later...Yes for serious pros...I thought about soldering your nuts in place Gene but then figured we would not have another 83 pages...
Thought you might like the experience of soldering your nuts in place.
I believe so. We will be in for a treat with his assembly photos, he is a pro...and very willing to be helpful too. Listen well Gene.gotta learn...better sooner tgan later...
i was wondering if music man got the backplane kit also??
