Yep, there is probably 1000 different preamps built over the years, some were great, some not so, where would you start? George is right. With a little digging, you can find the good ones have upgrades done over the years which helps the specs and gives them life for another 20 years. Grab a Carver C-1 and for a couple hundred, you can have a world class preamp with a bunch of bells and whistles and are so quiet you would be surprised. We have been doing these for years and they are awesome. Or, spend $500 and get a Acurus RL-11 and do nothing to it but add a Phono amp to your system. It's easy to find a suitable upgradeable pre which will fit into a retro system. Some pre's are not worth messing with as they have so questionable connectors inside (some PL/Carver pre's). I've worked with Glen on some of these pre's over the years and we have come up with a list of upgrades and posted them on these pages. We'd put these up against about ANY pre out there.
