Phase Linear Model 300 Series Two overheating on one side at low volumes
jtatknox
#42
I'll try to ferret them out!
While I wait for parts... I am struggling with the binding posts. The holes are too narrow for 12 gauge wire and they don't seem to work w/ standard banana plugs or have room for most spade plugs. What's a good spade connector for this old style binding post?
#45
I've got K's and I run 10 ga.
JT, post a pic. It's been years since I worked on a 300. Rattle my memory here..
NeverSatisfied
Houston Texas
#46
Are the binding posts different on a 300 compared to the others?
I use banana plugs on all my PL amps (400,700&D500) and I use 10 gauge wire.
12 gauge I consider the minimum and only for short runs.
jtatknox
#53
I will try these pins!
Project update: transistors arrived today. It was not easy to get in there, but I got the transistor replaced on the first try and now the amp is working perfectly!
I biased both sides and all is well.
I am waiting for new filter capacitors from DigiKey. Recommend checking bias again after replacing filter caps?
Another Phoenix rises!!!
jtatknox
#57
Always check bias when ya got er opened up...
Good advice. I will check bias in both units when filter caps get here.
On an unrelated note, I spent the afternoon replacing filter caps and installing Don's fantastic speaker protection relay in the Phase Linear 400 I have had sitting for 6 months. Very happy with how it all turned out except I can barely turn it up enough to make the VU meters dance before I get into noise complaint territory!
Can anybody recommend touch-up enamel for the VU meter surrounds?
#58
I and others just use a black sharpie magic marker, others bead blast them clean and spray paint.
#59
Or take paint stripper to them to get them down to base metal and then spray paint with color of your choice.
Perry likes lime green...
#60
Jani, ( my wife) uses a textured black...kinda cool stuff, just rattle can black man..
