So, bench checking the transformers isolation from ground I found a issue. With all 8 step washers inserted into the transformer, the cast aluminum cover was grounding to the transformer because it's so tight fitting. Chances are that cover was grounding from day 1 and was surely grounding the first time it was bumped.
My solution was to put the rear step washers outboard of the cover rather than inboard. So the transformer and cover have continuity, but are isolated from the cradle and chassis. Maybe not ideal, but that's the best I can come up with without adding extra insulators to space the cover away of the transformer and longer bolts.
It's now isolated.
It's now isolated.
