700/1 “Tim” WOPL driver board
AngrySailor
---not quite right
Did you have to readjust bias?
No, 350mV both sides.
Here’s a pic of light board. The screw driver points to the meter input leads from the speaker outputs. By removing both 10 resistors, the circuit will be open. 1C17335D-7F69-435A-919E-4FF2BFD2F38F.jpeg
Here’s a pic of light board. The screw driver points to the meter input leads from the speaker outputs. By removing both 10 resistors, the circuit will be open. View attachment 57034
The meter leads are supposed to come in on the same edge of the board as the 2 white ground wires are.
AngrySailor
---not quite right
The pads are labeled “hot” (meter?), ground and filament (lights). That is how it’s wired.
AngrySailor
---not quite right
Here’s the backside of the light board. As you can see removing the parallel 10 ohm resistors breaks the circuit. Those pads go nowhere but through those two resistors and on to the meter through then 23k and a diode, then through the meter to ground.
AngrySailor
---not quite right
Remove the resistors, then jump the holes on top that are not connected.
They would have to be jumped in place of one resistor each side so top to bottom to complete the circuit. Will this overload the meters as you’re removing 5 ohm of resistance.
Fug forgot pic. View attachment 57035
It is just one of many PL design errors. The board is wrong.
The reason that the meters are sluggish is that PL did not introduce the -20dB switch until the 700B, they then recognized that most users don't run their amps at full tilt (certain exceptions here)
AngrySailor
---not quite right
What are ya getting at Joe:p;)
ok resistors removed and jumpers in place. I think Tim’s ready to rock, got to repair my crossover now then it’s “go time”...
