400/1 “Linda” Full WOPL
AngrySailor
---not quite right
NEXT!!! This one getting the full deal, full comp, driver board, everything...
For sure. Tim could use one or two changed out also. Unfortunately there are several broken insulators on Linda, where they pass through the back plane. I won’t toss anything though Lee.
If they're junk, dont need em Andrew..
I’ll keep anything worth keeping. I’ve got a lot of the busted insulator parts also. A little crazy glue could make some useable sockets...
If they're busted they're too brittle..
Did they bust because brittle or because someone was a caveman putting them output retainer screws in? I notice you have to be careful as the screw goes through the insulator that it’s threads enter the collector tab easily or you would probably bust the insulator?
Mine looked like they pushed the socket away from the wall trying to get the screw started, then once started, snugged it up with a misaligned socket. Probably couldn't see through all that compound they slopped on.
Mine looked like they pushed the socket away from the wall trying to the screw started, then once started, snugged it up with a misaligned socket. Probably couldn't see through all that compound they slopped on.
That friggin compound... I’ll have nightmares about that slop...
Btw Mark, never knew you had a YouTube channel, I got videos to watch tonight, looks real cool what I’ve seen.
