- Jan 14, 2011
- Gillette, Wyo.
Yeah, that's enough Darc..
All 4?
Ok....having 100 volts plus to both outputs could mean a low voltage section problem common to both channels. The low voltage section is in the middle of the control board. With the board remounted, we need to check all 3 legs of each TO-220 , the top and bottom one. You should have rail voltage on one leg, about .8 on the other and 19 volts on the other. Do you have mini grabbers for leads??
I shall remount the control board and will use an infrared thermometer to check heat. How long to run it for before checking temperature?
Darc, I gotta get to bed bud. We;ll pick up tomorrow. I think we'll be better off if I get an assembled G board and send it to you. It's guaranteed bud, it'll be on me.
I am willing to pay for Cost and Postage of the board bud.
Thank you for your time Lee. I will take some pictures of the boards and post. Can't find any burn but there was definitely smoke.
