WOPL 400 Build
swarmin
Hello everyone,
With the current pandemic, I have found myself with plenty of free time on my hands. I am (was?) a line cook, but I've been into repairing speakers, recapping, restoring, built phone pre-amp kits, etc for about 10 years now. I had a side hustle selling silver plated oxygen free copper interconnects and speaker cables for a while on audiokarma.
I'm by no means a professional, but I feel I'm pretty handy when it comes to this sort of stuff. I am having some trouble with putting this kit together and I think it stems from there being too much information available.
I am doing the back plane board kit, the control board and wattsabundant relay. I have a few questions:
1: how do I avoid using the Zoebel network on the Watts relay?
2: The Q6 Bias transistor is soldered to the board, correct? I found some documentation saying it should be attached directly to the chassis, but then found a bunch of pictures with it on the board.
3: what process should I follow with bring up? Pl14_20 first? Back plane? Kinda confused where I should start.
Thank you for your help
MarkWComer
Gaston, SC
1: Remove the Zoebel. I don’t have the schematic handy, but identify two resistors with leads twisted together and a capacitor located nearby. There is one arrangement each for left and right channel. Clip the leads, or as I did, desolder and remove. (Member Wattsabundant can give you more details...)
2: Q6 is affixed to a stud via a “P” shaped aluminum thermal clamp, and of course, the leads have to connect to the backplanes with sufficient length for the body of the transistor to be within the square outline on the board. When you install the backplane, put a small drop of superglue to the round top, slide on the “P” clamp, and tighten with a #4 lockwasher and nut.
3: For initial startup, the backplane leads to the PL14 aren’t connected, Initial startup is mainly to check that the power supply has no issues. Do this with the bottom row of output transistors installed. After successful initial startup, its okay to connect the backplane wires to the driver board (PL14).
Right! I was confused by this as well, but with a little hand holding from other members, I made it through.
GOOD LUCK!
MarkWComer
Gaston, SC
On the 400 DCP: Remove R1, R2, C3*, C9.
*- I think C3, it’s just next to C9. I have a video on the installation, but there’s too much motion blur. The video details installation into a quasi comp with the old point-to-point backwall.
I removed the resistors, not the capacitors...
Wheel-right
Your welcome, I may not have done my 400/700 yet but I've read tons here to get ready and remember some of it. Mark's videos on YouTube are excellent help too besides being entertaining.
Hello everyone,
Very sorry for TMI (too much information). I respond to not knowing how to do something by creating yet more documentation to explain how to do this or that. After a while it gets to be a large amount of info to go through.
swarmin
No worries at all. It appears just asking here is the best way to go when my brain starts to hurt! I'm really impressed with the quick replies and helpfulness. You guys are great!
MarkWComer
Gaston, SC
I think everyone here knows the frustration of being at an impasse for not understanding instructions clearly. Nothing more frustrating than being on a roll with something and getting stuck! We cover for each other here, I’ve gotten answers quickly myself. By no stretch of the imagination am I an expert- just a hobbyist- and glad to help if I know how.
It’s a good crew here...
swarmin
Rectifier caps? Not sure. I've see them on multiple builds now. Is this a thing of the past, or should I be concerned?
So, when I run the first bring up (if I'm reading this correctly) I'm supposed to have the backplane boards not connected to the chassis with the help of the nylon washers. Is this correct?
MarkWComer
Gaston, SC
Have a look at this video, maybe it will help. The bottom studs hold your bias transistors, the top left stud is your chassis ground, the top right stud holds the right board in place (all four of these studs serve to help hold the boards in place). The screws through your transistor collectors securely hold the boards in place.
So, yes- the backplane should be secured to the chassis by these four studs, and the bottom row of transistors for the initial startup.
The little capacitors on the rectifier aren’t absolutely necessary, but desirable. They reduce/eliminate switching noise from the rectifier.
Here is a picture of the PL700B or S2 configuration but the intent is the same regardless of the amp. Components in the assembly aid package are intended for the initial hold down purpose. 6-32 socket head cap screw, #6 flat metal washer, #6 flat nylon washer, heatsink, chassis, thread into backplane board PEM nut. Hope this helps you understand the purpose.
swarmin
Excellent. Thank you. I've been checking out your videos Mark, very helpful. That was the next one to watch. Guess I should just sit down and watch them through.
MarkWComer
Gaston, SC
They’re guaranteed to cure insomnia...
swarmin
I just realized the variable transformer I bought is only 5A. I guess this build is on hold until I get back to work...
Your 5A variable transformer will work fine for checking the circuit initially. The first power up is with the dim bulb and none of the outputs installed, so the current is low. There is no startup surge because you are slowly bringing the AC voltage up.
True, when you want to troubleshoot the fully-assembled amp with a 4 Ohm or 8 Ohm load bank at full power, you may want a 10A or 15A variable transformer.
Lee, you beat me to it by 4 minutes.
Do you have the dim bulb test set for powering up? It prevents damage where a variac won't. I live by it. Material cost is $10 or so. you probably already have most of what's needed.
swarmin
Ok, cool. I've got a dim bulb for the initial, but when adding the transistors row by row, 5a will do the job?
