- Jan 14, 2011
- Gillette, Wyo.
Yep, nature will prevail..
So, after reviewing everything, I think I'm good. In Mark's video, it says the dc offset should be between -.011V and -.017V. I then re-read the control board bring up and it said offset should be 0. -.3 and 1.1mV is about as zero as can be.
I'm just looking for confirmation. I still haven't listened to anything yet.
your readings are just fine. The voltages Mark cited were for the predecessor board revision which had higher offset voltages than the rev E board does
I've got an audible buzz. I'm guessing it's a grounding issue?
Edit: This is a buzz in both channels without an input and it gets louder with an input plugged in. I'm thinking about it and I didn't ground the shielding going to the front panel. I'm going to open her back up and get that done.
I want to say I read something that said not to. I've always only grounded one side of shielding on interconnects. I'm guessing this is different though.
Did you ensure your input RCA connector shells are isolated from the chassis? They should be.
Did you remove the bus wire jumper between the RCA input jack copper plate and the black (negative) speaker binding posts right above the inputs?
I have the rca ground to chassis. Don't know what I was thinking when I did that...kinda embarrassing. I'm going to solder it up correctly and give her another try. I really appreciate the help.
Yeah- I noticed that. I bought the E driver for the 700 project before the G driver was available. I decided to go for the G driver for the 700 and put the E driver in my 400- definitely a difference in offset. On the outside job (an 8 fin Series One 400) I took, the customer wanted the G driver since the cost between the two wasn’t much. As I recall, my DVM read zero for the offset.your readings are just fine. The voltages Mark cited were for the predecessor board revision which had higher offset voltages than the rev E board does
Hopefully you mean the fiber washers- not the nylon shoulder washers! Omitting those would make instant toast!they don’t have the insulating shoulder washers around them?
They were there, the metal washer was on the chassis. I also had kind of a crappy solder on my grounds. I was trying to do it without cutting any length off the wire leading to the faceplate. I just cut it all off and cleaned it up properly. Buzz is gone. Double checking bias and gonna give her a go!they don’t have the insulating shoulder washers around them?
Yes the black shoulder washers that are installed on all stock PL amps around the RCA connectors.Hopefully you mean the fiber washers- not the nylon shoulder washers! Omitting those would make instant toast!
AND ANOTHER WINNER!She's singing! Absolutely beautiful! I'm impressed and couldn't be happier!
I'm using a Kyocera R-461 as pre and a pair of heavily modded Klipsch KG4 speakers to test. Sounds amazing. Played 4° by Tool and man did it sound pretty.
Thank you all so much for the help. It feels incredible to pull this off. Pretty much the electronics version of a differential gear swap!
