PL-400 DCP and WO light board
#62
500 hz eh... 3 volts seems like a lot Joe. Not saying you didn't see that 2.99, I just don't recall input being that high to get 350....I'll pay closer attention when I test the next one..
it is actually half the RMS reading. The p-p is accurate, now updated in the RMS cells
#64
What am I missing here? If P to P is 4.2 then RMS would be 4.2 X .707 = 2.9??
Hi Lee
The RMS = Vp/SQRT(2)
The Vp-p is 2x Vp
Both are cited in the table as Vp-p is easier to set up if you are using a scope. The RMS is easier to set up if you are using your DMM.
AngrySailor
---not quite right
#66
Had my well pump for the house go up in smoke yesterday so have been a bit busy replacing that. Today I’ll pull her apart and lift the driver board so I can access the outputs easier then check bias. I was thinking about this and do I have to check a B+\B- transistor each channel? Their bias’ then add up (or cancel I suppose) which leaves you with your DC offset for that channel right? I really have to print a schematic as it’s a pain to see on my phone. And I need more coffee...
#67
DC Offset is measured across the speaker terminals. Totally separate measurement from bias...
AngrySailor
---not quite right
#68
Yep, I realize that but bias affects it no? As in, if your +rail transistors are biased on 500mv and the negative rails are biased on 400mv, dc offset would be 100mv+? Sorry if that’s a silly question, you’re dealing with an electron herding n00b...
AngrySailor
---not quite right
#70
This quiffy PL4000 pre amp just dinked Linda... decided to go full blast as soon as it powered on. Shut it off quick, changed the rail fuses and powered back up with no input signal. Smoked another fuse... not good.
AngrySailor
---not quite right
#71
Hmmm can’t find my stash of fuses... so how should I proceed to diagnose this? Power up on a 60w bulb then install one rail fuse at a time? Only the left fuse blew hard. Not sure if it’s the + or - without taking her top down.
#72
If the fuse blew hard you've probably shorted an output. Fuse em again and do the DBT..
AngrySailor
---not quite right
#73
Roger. Might be tomorrow, girlfriend cleaned the house up today after the mess I made with stereo gear, so I cooked supper then proceeded to eat far too much... pretty lazy rn...
AngrySailor
---not quite right
#74
Once again Linda’s on the kitchen table. I’ll look into her today I guess. I can’t find my box of fuses and I’m having trouble sourcing AGC or AGX locally, on a Sunday... otherwise I’d put the PL700 into service (without the pre amp which caused my problem of course), but I robbed two 5a fuses as I thought Linda just popped hers due to the volume spike, didn’t realize she was hurt worse than that :(
AngrySailor
---not quite right
#75
Here ls what I was able to source locally for fuses. AGC 4amp and 5amp. The 4 amp is the wire filament rated 125v. The 5 has no other markings but looks more like a slo-blow... they came from a gas station so intended for automotive. Yea or neigh?
#77
Use the 4A on the right Andrew. Looks like that is the 125VAC rated one.
AngrySailor
---not quite right
#79
Looks like the left channel outputs have been changed they’re the NEC transistors. The right side are the PL909. The NEC’s show no shorts c-e the 909’s ALL seem to be shorted.
