I see. If you took a wiper assembly out, you may have reassembled it 180 degrees out. On some pots this is a easy mistake to make, on others, the design won't allow this to happen.
Ideally, totally disassemble it, clean everything with Qtips and alcohol. Carefully remove any hard deposits on the rotating wiper and slip ring the least destructive way you can. All metal contacts should be polished. Carefully, very lightly, grease the tracks, contacts, shaft, and barrel with fader grease. Just a light film.
Carefully reassemble paying attention to orientation of the wipers. Then exercise it back and forth to "break it in".
Lots of conflicting info on the web about conductive grease, non conductive grease, oils, carbon safe, plastic safe, alcohol or not on carbon, shaft striction grease for proper feel, etc.
I just settled on using alcohol, Qtips, and DeoxIT fader grease.
