- Jan 14, 2011
- Gillette, Wyo.
Thanks Bud....
I'll get the kit from Joe tomorrow and take the bezels into work this week. I'll post up some pics on the outcome. I'll also check into what colors of powdercoat I can get. I know goal post yellow is pretty popular.Thanks Bud....
Haha... I can get a bunch of colors. I'll find out.With the Hiway Department....
I'm also going to bring the face plate in and have the laser engineer look at it and see if he can duplicate the script. Thank you to everybody that has helped me so far and has looked at this thread. I would have never gotten this far..... and I still need to WO this thing....
Your hold downs need a little offset.....
I gotcha, that'll work..
Until I can come up with something better this is my fix. Wish me luck on the bezel baking process, and if it works.....
First thing i done did two years ago when amp dragged over to house. I used Krylon semi-gloss after stripping meter frames. I posted full size shot of clip but do not know if original. Looks like 10-32 or 28 on tapped alum bar stock which would be easy to fab. Rat Shack was out of blue leds so I used whites after going over meter stuck movements during that time.
The CLIP
Mike
