Russ' 700B Wopl
grapplesaw
Vancouver
Have you checked out Daqarta?
Lee I have that but the demo time was over before I got to use it. I have Arta 1.8.5
it is good for spectrum analysis and can generate sound but not as well as the Keithley.
I I guess I sould look at daqart again. I would like to do sweeps with a chart recorder like you do with the Audio Presision
The AP is a godsend really, it takes a lot of work out of it.....
I paid 100.00 for Daqarta, have used it once, years ago. I still get updates, I think it's up to version 10.....
grapplesaw
Vancouver
Anybody have a Mouser part number for the stand off you are using?
Hi Fred. I found these on eBay 1-1/2" search item #251759479387 I used them at this length in the 700
I have bought from this guy and I am going to order some things from him this week end
Glen
For some reason on this faceplate, probably due to overtightening of the meter hold down screws in the past, I couldn't get the meters snug. The hold down brackets ran to high in the pivot slot. Sooooooooo..........I formed a slight bend in the brackets.....
It's Joe's newest idea to deal with the uneven heating of Q1, Q2 on the low voltage section. PM your e-mail Glen....
