- Jan 14, 2011
- Gillette, Wyo.
Coolness.....
What a pain in the shitter that was. I had to break out the dremel to get the coating off the solid trans wires and rectifier tabs to get them to take solder. So far, this has been the hardest part of this refurb. Hooked her up to the DBT for 20 minutes and no fire, smoke, lava pouring out off the desk onto my brand new work boots. I'm not used to this electronics game. I turn metal into chips; but this has been a satisfying challenge. Bias and DC are good plugged straight in. Gonna go see if this thing turns my speakers into charcoal and dust. Wish me luck......Holy Hell in a Half Stack! It's a good thing it's not Sunday yet, or I might have burst into flames. I decided to play something period correct and Children of the Grave just sucker punched me into Oblivion. Thank you for the help so far... I've put this thing in the red and there's no turning back.
You're screwed for life now bro!! Don't give yourself a You are running a DC protect....right??
Will rubbing your finger across the lens move the needle?
I went back to the garage and the needle was sitting in the far left position again. Powered it up and it is working somewhat. Thats the one that was lazy to begin with and it seems a bit slower now than it was before. I will check for interference inside. Is there something I can do to a circuit to speed this one up to match the other one? Someone has messed with the light board and added a plug to it in the past.
What kind of plug? Take a picture when you open it up.
