Need help to repair two phase 400 amps
After you post you need to either refresh or navigate off the page and back again. I don't think you've read all my posts....go back to the last post on the previous page and check all my posts from thereto here one more time....please....
That's normal....don't sweat tenths of volts right now. What are you reading without the DBT inline....
LarryD
Paradise, Ca
I am going to strip the wires and tin them. How far back should I cut them? And I will leave you alone from here, Until I receive the goodies!
LarryD
Paradise, Ca
I will be watching for you. And thank you very much. I know I have not been a very good student. But I have to say I have learned quite a bit but still have a long way to go!
Thanks again Lee, your a cool dude!
LarryD
Paradise, Ca
Hello Lee, Yes I have and they seem to be fairly straight forward. But I am sure I will need a little help. Is there anything else I can do?
You'll notice a solid wire going from the input RCA ground plate to the speaker negative posts. That needs to be cut out, and the white wire that went from that same ground plate to the board, eliminate that...
