- Jan 14, 2011
- Gillette, Wyo.
Not a problem...
			You put the caps back in and taped off all the wires in 4 minutes?
Goin to bed. Gotta be outta the house by 5am. Good Nite....
In the meantime. Remount the caps, tape off the ends of all exposed wires off the boards. And build a cap discharger , consisting of a 50 to 100 ohm, 5 to 10 watt resistor with a 6" or so piece of wire soldered to each end, and then solder an alligator clip to each end. Then heatshrink or tape any exposed wire on that assembly.
See ya tomorrow....
Lookin good Larry. Have you checked all your fuses??
I just got back from a 44 mile drive to get the resistor. Radio shack did not have anything close! So I asked Siri for a fry's. The nearest fry's is 96 miles one way. So if it is needed for the test we will have to put it off. But if it were for my safety screw it, I will be carful.
You can check voltage in the caps with your meter to see if it's safe to do any work in the chassis....
