Gibsonian
- Aug 3, 2011
I wonder how electrostatic systems figure in the damping factor mix. Do they have similar mass/inertia characteristics as cones?
Just how many dB's of headroom do the WOPL500s and 1000s have? I read the lowly Proton amps brag about just over 7dbs and I know my amp will stomp a Proton into the dirt and piss down it's speaker jacks. I am guessing around 12 or better for the 500?
^^^^ That tells me nothing about a WOPL's rating. I have a Peavey CS800 that has more power but cannot reproduce bass the same as a WOPL. I have yet to get the WOPL to clip w/ my CV's but I can get the Peavey to clip easily
CS800 has far less power than a PL 700 or a WOPL1000 (PL and WOPL are nearly the same, WOPL a little more power), so that would explain some of the bass difference. Damping factor is also higher for the PL design, which in many systems, esp active crossover systems, can contribute to better bass performance.
In regards to the headroom, the Proton design is dual rail I believe and was designed for exceptionally high headroom, but cannot sustain the power that it can produce in bursts. It's comparing apples and oranges really. The WOPL has a lot more power but less headroom for sure. Headroom is a ratings/marketing game for the most part, but in the Proton amp, is really quite a bit higher than most others due to the amplifier design.
The WOPL I was referring to is my own 500, not a 1000 and the 500 stomps the CS800 in every aspect. I associated damping factor w/ headroom so perhaps this is where I am confused. Regarding headroom of the WOPL, I can lay my meters over flat and leave them there and still keep turning up the amp until the tweeters and mids trip in the CV's, the amp still sounds clear as a bell at that point. I thought damping was the ability to reproduce low bass frequencies at high power levels without clipping and keeping the bass tight. The headroom aspect I thought was the shock factor of dynamics which is what the WOPL does with high hat or cymbal crashes, downright startling... like your right there with your face next to a live drummer. I call it the blink factor because a high hat crash or floor tom hits will make most people in my house "blink" if they are by the speakers
The Spec 2's is 50....
