- Jan 14, 2011
- Gillette, Wyo.
Yours matches my sample Lee. Glen not sure what version you have.
Maybe Don can shed some light on it...
Just saw that as you posted JoeYou have a RevA, Lee and I have RevB samples.
Lee I am going to email Don and clear this upMaybe Don can shed some light on it...
Lee Can you post a photo of the other side as wellMy blanks don't have any D4's either, just 1 thru 3....
These boards are realy differentYep, know exactly why you ask...here ya go....
How did they get the water to stay in the pool?
Back at the project again
got new DCP boards from Don, thanks again for your great service, and have finished all the wiring.
I am looking for the thread which I read with all the steps to bring this puppy to life, so if anyone can help me please to find it I would be thankful. Want to put some juice to it before putting in the power transistors
View attachment 20026View attachment 20027View attachment 20028View attachment 20029View attachment 20030
Glen
Don't throw power to anything with those long screws installed that I see jutting through the standoffs in your picture unless they are insulated with a nylon washer from the heat sink side.
You will not like the results.
Thanks Joe
I will check for ground fault first
Yes they are going through rubber hose to avoid any grounding
have a look at this photo and tell me if okView attachment 20033
