- Jan 14, 2011
- Gillette, Wyo.
What's at 20hz...or 10hz?
I agree with Lee. That is one sweet looking amp you have there. The workmanship it top notch - great job Glen.
Did you put heat shrink on the DC protect board standoffs? Keep us posted on any further testing and of course how it sounds.
BTW - nice test equipment.
Thanks DennisI agree with Lee. That is one sweet looking amp you have there. The workmanship it top notch - great job Glen.
Speakers tomorrow LeeThat's what my math works out to also Glen....Good job on the amp. Have you had it on a pair of speaks yet??
Lee I am not happy with distortion resultsWhat did you have for residual noise Glen?
I have being dying to do something different with themYes , the amp is capable of less than that. A residual noise measurement is with one of those fancy voltmeters ya got with the inputs on the amp shorted, then measure AC voltage. Should be in the 200 to 400 MICROvolts...
Murphy is hiding everywhere!!!As Joe says.....refer to Rule #1------check your test equipment....
Lee do I do this with or without a load connect to the output?Yes , the amp is capable of less than that. A residual noise measurement is with one of those fancy voltmeters ya got with the inputs on the amp shorted, then measure AC voltage. Should be in the 200 to 400 MICROvolts...
