I appreciate the suggestions Joe, Lee and Doug, thanks. What I ended up doing was running the 10-24 tap about 3/4 of the way in and backed it out. It didn't seem like it was taking much of the aluminum out, it went so easily and when I backed out the tap, a couple little shavings came back out with the tap. Then I threaded the rod into the hole and when it stopped, well short of the distance the screw was in, I turned it with a nut driver over the two nuts and went the rest of the way, stopping 1/16" or so from the depth the screw had been in.
The instructions say to attach the two black wires with ring lugs coming from the transformer to the rearward cap screw. The black wires coming out of the transformer were attached to lugs on the bridge rectifier as were the green wires with the ring lugs so those are the ones I attached. Is that correct? I had to extend the white wire from the transformer to the copper bus so it would reach the end of the new, longer resistors without being bent fairly drastically in the middle.
The upper capacitor's rearward connection point is supposed to get the red wires with ring lugs and the photos on the instructions show the old point to point wiring on the back wall, not the backplane boards so I'm not sure what wires go to that spot yet.
I installed the bottom row of transistors with silpads starting from the transformer and going away from it in this order-95-96-95-96 and snugged them down. Now I may have missed it or perhaps it comes in a later step but I didn't see anything about soldering the transistor leads. Do these solder cups have some sort of contact inside them that eliminates the need to solder them or am I just getting ahead of myself and I'll be told to solder them farther along in the assembly?
Attached are some more photos so you can see what I've done up to this point. Thanks guys!
