Based on what I see here, you may not have a ground to the control board.
It appears that the original jumper between the speaker terminal negative and the copper input plate has been correctly removed. There seems to be a white wire connection between that same copper plate and pin 5R of the control board. If this visual is correct, then my recommendation is to remove this white wire between the copper plate and pin 5R and replace it with a white 20AWG wire connection between 5L and the copper bus bar between the 2 caps.
I cannot tell for sure but this is what it looks like.
A couple of close up shots around the input plate to right side of control board would help, as well as a closeup of all the wire connections to the bottom edge of the control board.
Thanks for your tip Gepetto.
I already put in place a wire (the red one on the copper bus) between 5L and the copper bus, following Laatsch advise. I suppose I can just remove the white one to 5R then?
I'll supply you quickly with better shots.
