Firstly, I'll just say, I'm not here. You are not really reading this. You're just imagining you are. OK?
Now, re: fuses D2, don't you dare. All this hard work, and excellence reduced to pass through a piece of wire not much thicker than a strand of hair? I will hear no more of it regardless of how good ANYONE's argument is...
About D2's up coming soldering skills being put to the test. It would be more practical to connect up some leads to wherever they have to go, to a small terminal block. Then D2 can just screw his flying leads on the x-former straight to the block. No solder necessary.
So there.
… your can all back to unimagining me now.
ps: really really REALLY nice work Lee.<SCRIPT type=text/javascript src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/cf12aae/background/helpers/prefilterHelper.js"></SCRIPT>
How on earth am I supposed to melt my voice coils if there are fuses in the way?Warming up the AP now D2. Not enough power supply to max out but we'll get the rest of it...
Very true, let me put it like this, I have more transfrmers here than God. I only have one in a power supply built with the right rail voltage. That ONE is not big enought to approach 500wpc. Wouldn't make any difference anyway, the max out will be dependent on the ONE YOU have...
Here we go.....done...
