I want a Reel to Reel
MarkWComer
Gaston, SC
#24
Is it practical to operate a Reel To Reel set on it side.
As long as the reels are locked on it shouldn't be a problem- you can even lay it flat on its back. I don't think there are any rules regarding the orientation of an R2R deck.
Fishoz
Northeast Illinois
Always learning!
#25
Not on it's side but laid down flat - a lot of units are made that way. Doesn't look as good though.
I have not made any comparisons, other than my A4010 and A3300s. They both sound pretty good - I'm satisfied for how I use them.
The 4010 is a sought after machine, along with the A7010. The 4010 is only a 7" reel. The 3300s handles up to a 10".
Laying the unit flat makes it easier to clean and demag the heads.
I thought I would be spending up to a couple hundred to try the R2R's out. Didn't rush into things and found two this summer at garage and flea markets for 1/10th what I was willing to spend - leaving more $'s for an eventual WOPL.
Nick Danger
#26
That isn't an option in that the turntable is on a sliding shelf that rolls out about 2" to allow the dust cover to open. But I guess I could ditch the cover and put the tape deck in that spot. I know I never see a dust cover on any high end set up anyway. Not that my gear is high end. Interesting thought. That space is17.5 H x 24.5 W :profileright:
Ric:glasses2:
Possible to remove the hinges from the TT's dust cover? Take the cover off when listening and toss it back on when you're not.
Nick Danger
#27
Not on it's side but laid down flat.....
Agree on flat and would steer clear of it being on it's side, too. I have seen folks that have space issues who want an open reel deck with 10" capability and set them on amp stands.
#29
I've had more really nice broken Teacs then YOU...
Bob Boyer
Chattanooga, TN
Not as well known out there - but don't ignore the Pioneer RT-701, which is the non-auto reverse version of the 707. If you're willing to get out of the easy chair a little more, you might find one for less than a 707 because of the lack of auto-reverse. Otherwise, it's the exact same machine.
Also - for your space considerations - the A series Teac would be a 2300. There are several iterations, including a version with Dolby, but they're getting pricey these days as well.
#38
Jase is still having problems posting pics, so he sent them to me and there they are....
#39
Thanks for getting those pictures posted, Lee and Jason. First I've seen of that model. Some interesting features.
