Australia
Prometheus is Benji Vaughn and Simon Posford......
Right done....on to the worlds first .......
WHITE OAK AUDIO PL700B CHASSIS!!!!
And this may be the first one where EVERY STINKING WIRE IS THE TEFLON SILVER KIND.....cause there are no wires in the chassis right now....
I'm very excited and honored, much respect Lee. Please explain the teflon silver wire.
Australia
2 or 3 of these beauties will be providing cooling for the WOPL. I may go with blue yet.
Very Nice!!
The transformer cutout is perfect....
This is a weird fellin guys....knowing every nut, bolt, bracket, terminal, wire......EVERYTHING will be put in NEW!!!!
NavLinear
Nav....would you please????
Ok - the wire Lee mentioned is used in many applications but was designed for use in harsh environments. One of my favorites and some of the stuff Lee is using falls under MIL-W-22759/11-Color.
This wire type is made with 19 strands of silver plated copper conductor with an insulation of TFE non-stick coating, a 0.010 inch nominal wall thickness with a voltage rating of 600 Volts and a temperature rating of 200 ºC. It's really good shit. You don't get meltback when soldering unless you dwell for a really long time and the solder flow really well with this wire type.
NavLinear
Very Nice!!
This must be a first and it will be great to see it complete. I think it is getting close to being a White Oak amplifier as fewer Phase Linear pieces are used.
Will you sub in a transformer to test it?
