You don't need to tip cows...they work for food.
George was right....this amp was trashed...
That amp would have had a very hard life on the road until it met its final fate with the truck rollover.
The only thing I'm gonna use are the heatsinks, fuseholders, and thermoswitches....
All new Buddy....this was a fully comp amp too....are you going to want to run fans off the aux plug? Or do you have 240 volt fans?
To Make it easy for you, I will run the fans off an independent power supply. I'm thinking 14 blade dynamic fluid bearing aerocool fans. They push a lot of air and light up nice.
OK, good. That'll make it easier for you to wire up the transformer also...could you post a pic of the transformer here?? Where we can see the wiring?
Excellent pics on the transformer....Nice fans!!
Not much lleft...
Not much lleft...
Thanks Lee, that's only a basic fan, sucks the hot air up and out of the amp, the 9500s runs too hot to not be fan cooled, that's why it has lasted. But I will be getting some more 14 blade fans for the WOPL, they are $25 a piece.
Is that a grommet on the floor?? cause this is missing one....
