- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
R70? that don't exist.
YOU TOOK OUT A WHOLE ROW OF NEGATIVE OUTPUTS AND THE D9's LIVE????????
Don's shit works!!!
Maybe... I like the idea of turning up the sensitivity on the pots then finding the right value to insert in series for the 0dB setting. Gotsta get the switch first, then we'll see.
Or Joe'll reply heheh..![]()
Don's shit works!!!
Fuckin' A right, it does LOL.
Need to put "pimpin ass bass" on my tagline lol...
Man, does not even look like the D9's woofer was really moving a lot when the amp went!!!
So even though it went kaput, the protection worked as designed?
Yep.. totally independent and dropped that relay out within milliseconds.
Well, got the parts on order.. we're backing up ten yards, but we'll get it. That's why we beat the shit out of them before sending 'em to yas!![]()
Drive it like ya stole it, bro! Any thoughts as to what the culprit may have been.
Ok, here's a quick update.
Replaced all outputs on the right channel (left is fine). Replaced Q7 and the resistor quad that smoked. Double checked Q9, and HERE is where I think the failure occurred as it was short collector to emitter. Replaced that one too.
Powered up, and the right channel was way positive (on the order of going to the rail, basically). Started probing the backplane..
DAYUM
In addition to every negative output gone, the "hit" took out every emitter/current resistor... opened it right up. And the 10 ohm bias resistor for the negative half, and one of the positive resistors!
Well, now we're going to be lifting up the right channel backplane to replace 'em. I believe I have a stash here somewhere.
More tomorrow.. long night, and I'm bushed. But the end is nigh.. Hope to have some "pimpin ass bass" going through it again tomorrow LOL..
Jer did you have AGX5 fuses in the B+/- rail position?
