Does your meter have a frequency function?
No, but I 've a cheap scope here
I would guess your pre amp is noisy...possibly the mixer too. Could you take the amp to pre-amp RCA cables and leave them plugged into the amp , un[plug them from the pre-amp and then short the ends of the RCA cable by taking a small wire wrapped around the middle prong and then to the ground shell of the cable?? What we are trying to do with that is eliminate any influence of the source...
You mean shorting Left Right channels or shorting each channel with its ground?
I'm planning to test that tomorrowtry different RCA cables if you have not yet. The thing about the shields being cut makes me wonder if that is the problem. A different set would be a simple enough test.
I also noticed on your Bridge Rectifier you have no snubbing capacitors.. A .01uf / 400 volt polypro or mylar caps accross all 4 lugs will help a bunch. This could be the source of the remaining hum....
I don't advise putting these in place because of increased power supply cap values, but rather to cut down.on the switching noise if the diodes within the bridge rectifiers. One cap between each two post combination on the BR. 4 total...
