- Jan 14, 2011
- Gillette, Wyo.
Could you take a close up picture of the rca inputs and the driver board connections?
Pre amp on first if the speakers are still wired up.The routing of the unshielded input wires coming from the RCA jacks should be run along the bottom of the chassis then at right angles up to the board. I've noticed they are laying right on top of the bus bars for the output transistors...Unplug the TV cable box if there is one in the house. Also, do you have light dimmers anywhere??
