If the problem persists you may want to open up the top - maybe one of the ICs was dislodged from it's socket. I am assuming that the ICs are socketed tho...
Well here's the updated pio vrs 3600 pre thing!! Laz will appreciate this..
But I've been bitching that I couldn't get any low end out of my system . So when I just got the 1250 back I used it straight then as a pre. And I had all the lows. I had written it of as dudes xover design. But the pio was like whoa. But I lost a lot of detail and accuracy with it. So I hooked the 3600 back up and sure enough no low end. I got a bit mad so I had the old (kick it) thought running through my head. So instead of kicking it I unhooked it and from about 3 to 4 inches off the concrete and dropped it.... And guess what!!!!! ITS BACK..... This thing is badass now. All my lows are there. The clarity and detail and accuracy and BASS !!! Now this thing is sounding good..![]()
It's the simple kick it logic. Works everytime !!!! Well some lol
Ok, gotcha
Would a line stage preamp work then?
Ron: A simple line stage preamplifier won't have an RIAA phono equalization circuit and won't have the needed juice to supply enough output to the amp from the tt cartridge.
I sent my tonearm today to have a rewire/upgrade done. So I pulled out the uturn orbit plus! What a shitty table. This is one of my purchases that I wish I would of nvr made lol. It has a ortofon om5e cart. What a shitty cart. God this is terrible. Time to mount a diff cart on here and see how and if that helps!
Would you sell it?
Would I sell what? My tonearm?
The Orbit, which you cussed so roundly.
What you got another 550 Ron? When did u get that?
Yeah, I got it a few months ago from an AK dude, it did not come with a dustcover or headshell so I am using the ones off the other. The table works great, I would not offer it otherwise. Just the minor issues noted. $100 + shipping
