- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
Got you a pair of cuties there Jason, raise 'em good!
AK should have one in their Pioneer forum..
Unfortunately, I don't believe the SX-1250 is compatible with a low output MC cartridge. You would have to use a step-up transformer to use a low output MC cart with the SX-1250. If it's a high output moving coil cartridge with 2.5 mV you would be OK.
Probably a no go for hooking up a powered sub woofer to your SX-1250.
It shouldn't run hotter than that 700.
Yes sir. Those receivers are not supposed to run hot. Especially not loaded up. Makes me wonder about the bias setting
Yep. Email him bout the heat issue. See what he says. I'm real curious.. The Specs are the same design and I've never needed a fan on.mine...have you checked the heat when using the amp section.?
