- Jan 14, 2011
- Gillette, Wyo.
Hookay, we have an agreement...
Lee, I forgot to say that I have PL 700 fan kit to plug into the 110V AC socket on the back.... Too late?
Well, that's really the only place I can shoehorn in the IEC socket. Surely you have another source for the fan??
OK, is the aux socket 240 or 120?? If it's 240 in that's usually what the aux socket is too unless you run a ground and one leg of the 240 and that's not how this one was wired...
Lee, if you started drilling, could we swap the AUX 110VAC socket below, somewhere next to the AC fuse holder? Or indeed put the IEC socket aside next to transformer? Sorry for late reaction...
It appears it has an additional winding on the transformer, or a dual primary where you could tap 120. Did you have 120 at the aux socket?
Looks like a painted chassis...
Yep...
Przem, We can change the type of plug used on the fan and come out the OLD AC mains in hole....I'll send the male part of the connector we use so you can convert the fan cord....OK?
That picture was of the other mine PL 700 II. And the chassis was painted there - you are right!
This one is correct...
The bean counters at work again...
Going to Timdalf's for dinner , drinkls and fire works....later, I'll be on my phone though..
