Nope, bring it back up to 50%, then ADJUST bias using the pots on the top side of the board. Use your fingers or a plastic screwdriver. I hope that right bias wasn't MINUS 10 volts DC....
That being the case, I checked the Right channel first. Lowest reading I could get was .912V, DBT dimmed somewhat while turning that bias adjustment all the way down.
Lowest I could get on the Left channel is .319V. Adjusting that bias pot did not affect the DBT at all. It barely glowed and did not change.
Only way to adjust right bias is up, the control is hard over down. Adjusting it increases DBT brightness and I had it up to 2 volts before backing it all the way down again to 1.74 volts.
EDIT: Q7 & Q10 are slightly warm now and just noticeably more so on the right channel primarily Q7.
