Things changed for me time wise today and I was not able to get new co-ax cable until now - just got home. I was asked at the last minute by some friends to help with a move and couldn't bring myself to say no. In appreciation, they offered me dinner tonight so I'll be leaving for there again shortly. When you live alone,
you do not turn down a free meal. When I get back, I'll start replacing the co-ax cable but before I do, please advise what you think about the stuff I got.
I should have checked out the suggested cable ....
You are looking for shielded with a CM designation. 2 conductor #22, or #20. Either one...
Two stores I figured, were most likely to have it but neither knew anything about a CM designation. I described what I wished to use it for, explained there was a heat issued and that the original cable had foil in addition to braided shielding.
The first store showed me two quite thick cables (18GA & 20GA) about twice the diameter of what's in the amp. The second store first showed me solid core co-ax and then the cable I wound up buying. I was told it was used in guitar amplifiers and can withstand 85 degrees Celsius or 185 degrees Fahrenheit. The outer sheath is rubber, it has foil and braid for shielding, some textile threads but two centre conductors not one. If I can't twist those both together to make connections, I can use one or the other. Plus it's approximately the same diameter as the original.
Please let me know if you think this stuff is OK. It was only $0.58 per foot so no biggie if I have to find something else. Does that CM designation translate into an RG number?
EDIT: Scratch that comment about it being about the same diameter, it's way thicker. I'll cut off a small sample and go back to that shop in the morning and if no luck, will try the other two stores I did not have time to visit today.
