Q4 the MPSA92/93Thank you! It did not occur to me that a transistor would be inside that backet. I know those things as Loomis Clips.
If that's where the 2N5088's go, which transistors get these heatsinks?
 Understood. A picture is worth a thousand words. I'll do that first before anything else on the board.
Since I was going to need some thermal compound for the heatsinks, I asked for some in an electronic parts store. They sold me this:
View attachment 14213View attachment 14214
Its called Stars DRG-102 and all the label "fine print: is Chinese. In hindsight, I'm wondering if it's the right stuff? It's grey not white and looking online, it's referred to as thermal adhesive glue containing 50% silicone - 30% carbon compounds - 20% metal oxide. Those ingredients sound electrically conductive. Is it OK to use provided none gets in contact with any pins or, should I get the white greasy stuff on Monday?
Also wondering about the power transistor insulators I was sent. Presumably, I'm to use them in lieu of the clear (mica?) ones that are already there?
If I am to use those new insulators, am I also supposed to use thermal compound as well? And if so, can I use that grey stuff?
The Stars DRG-102 compound would not work in this application as Lee said. The carbon compounds and metal oxide are conductive and would cause a major failure. The two legs coming out of the TO-3 package are the base and emitter - the case is the collector and must be electrically isolated from the chassis. The Sil-pads Lee sent you are very user friendly and have similar thermal transfer characteristics as the mica with non-conductive silicon based thermal compound. There is a torque spec with these pads and they are a one time use.
Understood and have dismissed the notion of using thermal compound since those Sil-pads make it unnecessary.
If you have any thoughts on my previous post, I'm all ears.
I am indeed honoured to have those brackets!
Also puzzled. I identified transistors comparing their actual part number to what's on the schematic and Q1 through Q10 match. But there are (3) 2N5401's and (1) MPA56. Is the latter a substitute for the former - are they interchangeable?
Also, I can't find these two transistors on the schematic. The one with number to the camera is MPSU60 and the other (green/red/orange stripes) is MPSU10. Do I just ignore these and leave them be? Are they a post schematic modification?
Looks to me that Q11 and higher are those on the main heatsink,
OK, thanks - think I got it.
Just to be absolutely, positively, 100% sure before I start, do I follow the pin out of the old transistors?
