No pics on the A60 restore?????
Turn on/off thump was history with the Rev "C" board, you definitely have a problem......
I'll take some pics then. It's been a piece of work. Got it from shopgoodwill for less than $50. It looked nasty. Cleaned it (definitely came from a heavy smokers home), deoxited it. Then discovered it had a bad phono input switch (NLA) I took the switches apart. Pics somewhere on here or AK, I posted trying to find a replacement. Took apart the bad switch, plastic tit worn off so no way to fix, so I ended up swapping switch position with AUX. Used the amp for about 2 weeks continuously on, sounded darn good with my Thiel's! A lot better than the Pioneer SA-6500. Well it eventually dropped a channel. So I've been doing a recap and some testing. I guess I should have taken some pics after I pulled the heat sink and all outputs.. It has definitely been hot! One of the big supply caps has been leaking... etc. I'll start a thread later, I'm whupped!
