WOPL 400 Build Problem!
#46
We asked that quite awhile ago, and you said you had checked them....so, all is well now??
#54
Nope, it's messed up..! Ordered new fuses.
here is a debug hint. You can tack solder a 10 ohm resistor across the Pico fuse to help you pinpoint your problem area. Locate and fix your problem and then once fixed, replace the fuse else you will just get frustrated blowing fuses. There is a reason the fuse blew
nadude98
Terre Haute, IN
okay, i'll do that. Thanks!
nadude98
Terre Haute, IN
Okay, here goes. When I tested the outputs at first, after blowing the pico fuse, I tried testing them using the ohms function and when I did that all the MJ21196's tested bad... When I did the diode test they tested ok. Well, I did as Joe suggested and tacked a 10ohm resistor in place of the pico fuse and am bringing up the amp with backplanes installed just like when a new install. I installed the bottom row of transistors and did a resistance check from output cases to chassis ground. The cases of the MJ21196's on both channels are measuring 2.8M ohms to ground....?
nadude98
Terre Haute, IN
Ignore some of the last post... doh!
Okay, the back planes are reinstalled, with all outputs, and with a 10ohm resistor in place of the pico fuse. I'm am triple checking everything.... and from here I will not do anything but what you tell me to do.
Here is where I'm at.
What would you like me to do next... ?
