Transfering from one external hard drive to another???
The connector on that drive looks to be USB 3, but it will only do high speed if its connected to a USB 3 port on the PC. These can be identified by looking at the ports on the back of the PC. The black ones are USB 2 and the blue ones are USB 3. If you don't have USB 3, we can still use USB 2, it is limited to around 35 meg per second. Provided there are no other issues, this will also get the job done. USB 2 will take 17-20 hours to copy 1.8tb , using the sync program I have in mind, which will ensure the bitch don't fail half way through. You can set it and forget it for a day and it will get done.
Done ....7 hrs 59 min..
could be interested. have a 36 terabyte NAS.
Well?? At one time Darcy e-mailed me an index, perhaps he can put it up here, that way you'd know what you were getting..
PM your email to me, and I will send. Note that the stuff that has not been processed and tidied wont be included until I get to work and sort it.
Lee, did you figure out what the drive is? And, did you get the cash I sent you? COOL!
A Western Digital HDD, yes a spinner...
4tb drive obtained for Lee, give me some time and I will have it sorted by the weekend. Cheers bud
