- Jan 14, 2011
- Gillette, Wyo.
Glen, are you going to keep the lo/hi Z switching of the transformer secondaries??
Hi LeeGlen, are you going to keep the lo/hi Z switching of the transformer secondaries??
Spent several hours on mapping out wiring for full comp setup today. I have found that many errors are the 700 comp drawings. I will need to modify the out put stage on the cp boards and now have arranged all the wiring ( I hope) I found that the original wiring on this unit was different to the drawings and my other units. I am now sure this was a proto type unit.
One wire to decide on is the sensor for the high frequency unit. It was on the emitter side between the transistor and the emitter resistor. On B- side Haw the these are inverted I will move the wire to this same layout on the full comp set up.
BastardBead blaster?? Yep, we got one of those too.....
MmmThe machine tools don't come into play much......
What caps did you wind up with??
I got some with no holes extra holes and some with three so I did up 6 in about 5 minutes so that should hold me for a little while.I need to look more closely when I order also, I n need the extra holes for the ac feed for the DC protect....
