- Jan 14, 2011
- Gillette, Wyo.
Why do you bypass the electro's on the driver boards Joe? not enough uf's ???
Hi Lee
Only bypass on the control board is the 2 on the OPA134 which is the manufacturer recommendation (Burr-Brown/TI) in order to achieve the GBW, stability and PSRR specs that they advertise.
The bypass on the backplane boards is to counteract the effect of chassis wiring inductance at higher frequencies and prevent resonances that potentially result from that .
Both are placed right at point of use where they do some good in the above regards. The same placed at the bulk caps would have no effect.
Last contest item today is what to do for the output jacks.
This unit has banana plugs ( one way only ) I personally like these as the plugs are tight and hard to pull out.
I could replace them with the three binding posts from the 700 as used in later 5
D500. Or I can use some brass 30 amp ones I have. Only draw back to these is they are not plated
I am really interested what you all think on these items so post away.
Here is some on Ebay that look to be the same.
http://www.ebay.com/itm/6-Position-...404211?hash=item5d4aa6cdf3:g:n54AAOxykmZTMzXH
Also Antique Electronic supply
https://www.tubesandmore.com/products/P-0602H
Thanks a lot. We will gon on Lee's recommendation on EBay ones
Happy New Years Everyone!!!!
I am sorry for the delay in answering your post. I just got back from the east coast where I visited with some of my relatives over the holidays.
I also visited with Mark Weiss http://www.basspig.com. My brother-in-law and I had a great time discussing audio (as well as other things) with Mark and will be back in 2016.
The terminal strips were made by HH Smith now Abbatron HH Smith (632 Arch Street, Meadville, PA 16335)
http://www.farnell.com/datasheets/1927258.pdf
http://www.abbatron.com/uploads/pdf/SD-3000 SER.pdf
http://www.spectron.net/Abbatron - Catalog.pdf see page 29
Phase Linear also used their terminal strips, speaker binding posts, strain reliefs, etc.
You should find the price from their dealers (not from the guy on ebay who wants $22.97) to be less than half of what you see on ebay for the items noted in the previous posts.
Ed
Skycraft had them at $7.95 for 10 of them which is an excellent deal.
