Sutt's "Fugly One" WOPL Transformation
oldphaser
Jerry,
How did the amp test out at 20kHz, both channels driven (at the same time) to rated output for T.H.D.?
700B: (i.e. 52.5V @ 8 ohms for 345 watts)
or
700 series II (53.66V @ 8 ohms for 360 watts)
Ed
bill7621
Berlin Center, Ohio
WTF, y'all
Here is BEFORE
And AFTER
I think the transformer, the heat-sinks, the name badge and the knobs were the only things used in the new build....and I have some new knobs coming from China...
Sure is pretty. I'm sure you're going to get years of enjoyment from her.
Another WOPL lives to fight the fight.
She ain't fugly no more!
ksrigg
Wise, Virginia
She is a beauty, for sure. Not the same amp that left here a couple of weeks ago. She is also a real brute with just effortless power and finesse. I remember when Kevin got the latest revisions done to one of his amps and we did a comparison. First we listened to a
WOPL with earlier revision boards .....and thought it couldn't sound any better than that. Next we listened to the latest revisions, I both of us had our mouths open.....muttering.......my GOD......that is not possible. The latest revisions done by Joe and built by Jerry just gobsmacked us both....and we thought the early WOPL sounded good.......but we were pretty much both flabbergasted.......could not believe how much better the amp with the latest revisions and back-planes sounded.....I was convinced.....and now have TWO 700b's and one 400 with back-planes and all the latest and greatest....and I NEED MORE.....it is just a matter of time...damn, Joe just keeps making them better and better, and Jerry just keeps building them better and better....they are better than any amp I have ever hear....by a huge margin. I sold all my Bryston gear after hearing the early revision WOPL....they are THAT GOOD....no......GREAT!
ksrigg
Wise, Virginia
You got that right , Joe...ain't nothing like it. I have her jamming now.
Streaming from the internet is terrible. What happened to CD, SACD and analog sources? I know streaming is convenient, but it sounds terrible..
ksrigg
Wise, Virginia
Where did you find them? I've looked and the ones I found are these, but I'm not sure exactly how they will look til they arrive..they are 38 X 22 mm and fit a 6 mm shaft .....so..........
ksrigg
Wise, Virginia
" lucky.warm " is the name of the eBay Seller. He had them listed for $4.25 I think, but I had a 10% off coupon, so I got them for under four bucks each. Only thing is, I think they will take a month or so to get to the USA...Here is the item description:
38x22mm Aluminium Alloy Volume Knob for 6mm Potentiometer Shaft Silver
( 182525783244 )
I just hope they will fit the shafts.....I know they have the hex nuts....so I just hope the opening is large enough to accept work. We shall see !!
grapplesaw
Vancouver
Ok you will probably have to drill open the shaft hole to .250” as you have ordered 6mmthis is a very small amount to drill out Back out the set screw so your drill will not hit it and place some tape across the outside so it doesn’t get lost.
Best way is using a drill press so you keep the hole square to the knob.
You do have to keep the knob protected from scratching and denting so wrap it in masking tape making sure the face has no bumps when doing so to get a flat square surface to drill against
Good luck
ksrigg
Wise, Virginia
Good luck
Thank you for the excellent heads up and solution. I will follow your instructions upon receipt of the knobs. I hope they look good....I hope they tie in with the new look of the amp and go well with the Acurus preamp I am planning on using..
grapplesaw
Vancouver
Try them on first in case the fit as is
My thought is that with all the additional current we are demanding from these amplifiers, we should be using 3-prong plugs and grounding the chassis to mains ground (earth). 15 Amps will kill you in an instant.
