Testing WOPLS "automated" by Jer...
jbeckva
Admin/Server Dude
Errm... Ey Vatos!!!!
LOL so like in Sutt's 700 build thread I alluded to playing around with an IEE-488 GPIB controlled testing platform, based on the HP8903A analyzer. Was thinking if I needed to also include the HP3455A multimeter, but I'll cross that bridge when it comes.
So basically, so far what I've done is to create a little program that sends the appropriate commands, measures, etc. The first challenge was to figure out how to actively measure the voltage gain RATIO for the amp under test. Since this is a fixed and linear value, in theory I could use it to calculate the appropriate signal input voltage for whatever I needed on the output. And it works here.. (pressed the amp gain button, the results are shown in the readout on the bottom)
How do I know this is accurate? Well from there, I was able to calculate the appropriate input voltage for a "specific" power output by first calculating what actual output RMS volts was required for the specified wattage..
E (out) = SQRT(P x R) where E is the voltage needed, P is the power in watts desired, and R is the dummy load resistance (8 ohms in my case).
Once E (out) is known, E (input) is calculated by dividing the output voltage desired by the amp gain already precalculated in realtime and specific to the amp being tested.
And here's the result.. I wanted 55 watts.. the 8903A is capable of such a measurement..
Going to one watt, even closer.. close enough for my purpose!
And.. hell.. here you go. This is from my other WOPL which is a converted 400. Not too shabby considering ..
Watts..
Distortion at said watts..Mind you, this is one channel loaded due to the 700 whacking one of my dummy loads so it's conceivable ...
So the next challenge will be to write a routine that will (slowly but surely) increase the power output until the associated distortion measurement reaches.. say.. .5 percent. That should be a good indicator of the amp's single shot power capability.
More to come...this is FUN...
jbeckva
Admin/Server Dude
Alrighty then.. so now we're back in business with 1000 watters that I would hope won't shoot fire out the ends. Also meet "NoFace" here LOL, which is a 400 WOPL build, fronted by an old 700 faceplate from a long forgotten build (but whoever recognizes it, feel free to speak up).
I found the clip point to be, with both channels driven (and 8 amp rail fuses!) .. around 302 before distortion started to creep up from an average level of .07 or so.. Watts shown here..
And distortion for the same output.. it would climb up fairly quick from 302. Now what I need to do is capture it, plot it, and display it. Checking into some .NET controls that should do the trick. I haven't had the need to explore em until now, so it's a new thing to learn. Stay tuned for some cool graphs and whatnot. I hope.. lol..
jbeckva
Admin/Server Dude
Working good, Lee. I just programmed in the "test" where I tell it how many watts to start with, how many to increment and at what level of distortion to stop. Both channels registered 305 (2Khz) at the .9 percent mark so figure yeah 305 at clipping.
Now for Ed.. here you go, and this is with a 400 WOPL. 20Khz @ "rated" power of 210 watts. Now also what was very interesting is that when I went to 20Hz from 1Khz (I power it up initially at 1K then issue that frequency change command), the DCP kicked in. At 20Hz I had to start low, around 100 watts then after setting it to 20Hz bump it back up to rated power. Well. at least we somewhat know that the DCP will do it's job, but yeah with "NoFace" here, the DCP is a bit funky ... will eventually get around to fixing it.
Anywhoo.. here's the spread..
20Khz
10Khz
5Khz
1Khz
100hz
And 20Hz (8903A's gen can't go past this.. sorry!)
I'd like to do the damping factor test next. But keep in mind that means two measurements like Ed said.. one with it loaded the other unloaded. That is where I JUST might go find the next IEEE-488 enabled test component.. something like this here to switch loads in and out, etc...
https://www.ebay.com/itm/HP-Agilent...-Switch-Control-System-Mainframe/281970015171
Ayee.. insanity at it's finest. I feel the mad scientist vibe pretty strong LOL
jbeckva
Admin/Server Dude
ps.. All this testing indicates that at least for this guy, I have some work to do on the right channel. Distortion on that channel was a tad higher than the left. Eventually.. that and the DCP. In any case, overall it sounds damn good like a good WOPL should LOL.
oldphaser
20Khz
Jerry,
Is the result noted above for single channel driven or both channels driven? I would expect to see (2) THD figures that are not exactly the same.
THD spec for a 400 series 1 amp is .25%.
A 400 series 2 is .09%.
So if you were using the same pc board in a series 2 amp it would not meet factory spec.
By the way, I have an old PL400C pc board in a 400 series 1 amp which I stripped down and re-populated the board with carbon film resistors, newer Nichicon caps and MJ series output transistors. The amp with both channels driven at rated output at 20kHz will do .073% THD in the left channel and .057% THD in the right channel.
It should also be noted that THD levels will change dependent upon the duration of test. In other words, heat will affect the results. The IHF-A-201 (1968) called out for 30 seconds. With the next revision: IHF-202 (1978) it became 5 minutes as is also in the current CTA-490-A R2008 standard. The FTC standards did not allow for the use of fans unless the amplifier came equipped with fans at the point of sale.
The Phase Linear 400 series 1 was initially rated at 200 watts per channel then increased to 201 watts after the release of the FTC spec in November 1974.
The 400 series 2 was rated at 210 watts per channel.
As for damping factor, obviously a higher resolution and accuracy multi-meter will also provide more meaningful results than a lower resolution meter. Play with the numbers by say .01V and then .001V in your calculations and you will see significant differences. Unfortunately for me, my meter reads only to .001V up to 20V and .01V thereafter. With a relay installed, I do not expect you to see a damping factor of 1000:1. More likely around 200:1.
The 400 series 1 damping ratio spec is 1000:1 at 20Hz.
NOTE: Phase Linear also did this for the original 700 series 1. However with the 700B, the damping ratio was initially rated at 20Hz in sales brochures, owner's manuals and early service manuals, then eventually 1kHz (as is noted in the 700/700B 2/81 revision of the service manual).
The damping ratio spec for 400 and 700 series 2 amps is 1000:1 at 1kHz.
NOTE: This does not include the PRO700 which had a lower ratio at 1kHz of 330:1.
Ed
jbeckva
Admin/Server Dude
Hey why would you want to use carbon resistors in leiu of the metal film types? I've done a few reworks with the MF's which drastically cut the residual noise in the circuits. Ole Larry used to say "resistors make noise" (something like that), and after scoffing a few times I tried it out on a Carver pre ... big diff! Guess it might depend on the overall design tho, but so far it's been a good idea for me.
