Sony TC-K950ES
Australia
#41
That's a bargain price on a really nice deck. Quartz lock is very desirable along with the other must have features. Hope it gives you many years of enjoyment Nando. Recording will be nice too with that deck. A service may make it shine even more. Now that you have had some time with it, how is the sound quality compared to your other main decks?
#42
Thanks, Derek. It sounds fine. My hope is it does well in recording. Once it has had a tweak & tune it will become my 2nd main deck for mix tape duty. I haven't recorded with it, yet.
braxus
Fraser Valley BC
#43
Good catch Nando! Funny as I thought you were looking for a Dolby S Sony, which the A3ES would have gotten you. How does she sound? If this unit uses the 200D transport, be prepared for it eating tapes now and then. The pinch rollers are usually the cause of that.
Puerto Rico
Hey Nando, congratulations! I've never been a SONY's fanatic myself but that's a wonderful deck for a bargain price! How you compare it to your Pio's? I'm gong to add that pircture to your profile at my website. :happy7:
#46
Thanks Scott, Daniël. Scott, prior to me making this decision, I had some good tactical points from Tony, who owns both the TC-K950ES and TC-KA3ES, Good thing I opted for the 950ES. Yes, I believe it has the TCM-200D transport. If anything, this deck seems to sense any tape skew, tape slack and stops playback before any damage is caused to the tape. The first day I got it, I must have logged about six hours of playing time and probably 10 hours in total since owning it.
This past Thursday night was my first attempt at recording with my new Sony. Downstairs, I have a Pioneer CD file changer holding 100 CDs - a PD-F904. I patched it directly into the CD Direct inputs of the Sony. Then I followed the OM on proper calibration procedure for the bias and level. I left the Rec EQ Cal in the Normal position. I used a new Phoenix Blue Chrome C-90 tape for the recording and I enabled Dolby C and HX-Pro. My CD changer is across the room, probably 15 feet way from my Sony cassette deck, and I didn't have my remote control handy so I had Geri cue the track I wanted to record on the CDP. I, only, wanted to do one track. Once I completed the test recording, I rewound the tape to listen to the recorded song. Very nice! I would say the recording had a slightly stronger bass tone than the source material, but it might have been the tape formulation. Any of you other Sony TC-K owners find the same? I usually like to monitor my recordings with headphones, but I skipped that for this test-recording. Happy with how that song turned out, I continued with another, then another, until I completed Side A. Each time I had Geri hit the Play button on the CDP as I began the recording on the Sony. Whatever CD was loaded into the changer was what I recorded a track from. The band playlist goes in successive order: Pink Floyd, Neil Young, Saga, Toto, Van Halen, Led Zeppelin and a double-track from Queen.
This is a very nice deck for recording and once I get it looked over it should be up to factory-spec.
#47
Thanks, Carlos. I am very happy with this deck. I don't have as many Sony stereo components as I do have of Pioneer, but I have been a big fan of Sony since buying my first pocket transistor AM/FM radios. In general, I have many more Sony products around the house than I do Pioneer.
Use any pictures which catch your eye. I have more cassette deck pictures to contribute, later.
BlazeES
Nando, that bass warmth is a signature of Sony ES decks. From what I've seen, the "effect" is more noticeable on Type I and Type IV, but still present on Type II and with no recollection of it ever being "too much". Personally, I've come to appreciate that equalization shift - it helps to round out older source material (60's and earlier...) without being a huge bump to the bass and lower-mids region. If you can pick out a CD that you distinctly remember sounding as being overtly "digital' sounding, I'd recommend transcribing that bad boy to a quality Type I and listening closely upon playback. I've always maintained that mid-to-upper lines of decks can help smooth out the source, especially on ES rigs. Warming is the best way I can describe it and Sony's do it very nicely IMHO.
That random track pick approach off the CD changer must have made for an interesting ensemble.
#49
Thanks for the feedback, Tony. What will be interesting is to see how recordings made on my 950ES and yours plays back on the Esoteric V-9000. I have a feeling the Sony recordings have a slightly higher output level seen on the Esoteric.
Seems all my old-school CDs are in the CD changer.
BlazeES
Good point Nando, I've seen that slight, overall level bump on tapes made on ES and played back on another deck, with some deck brands revealing more than others.
The tape you sent me seemed pretty darn close though, with no hint of being under recorded. Will be informative to see what your experiences are the other way around.
#51
Here's a short video clip of Scott's mix tape playing, today.
#52
Tony: On Side A of your mix tape, the first song I videotaped, "No Remedy" by Jelly Jam is such a good song. The change-up is catchy with a strong drum follow-through.
BlazeES
Tony: On Side A of you mix tape, the first song I videotaped, "No Remedy" by Jelly Jam is such a good song. The change-up is catchy with a strong drum follow through.
Rod Morgenstein on drums! And on that particular song, he really shines.
Dude has a long career:
Dixie Dregs
Winger
Fiona
Platypus
Jelly Jam
Australia
#54
It looks really robust and well built. Glad to hear the recording side worked out for you. Every deck has its own recording 'character'
