Soldering
#21
An educated guess is conformal coating Larry. A varnish like substance that is applied after component assy and wave solder. A photo of the component side of the board will help clinch that. I notice the darker green manually applied conformal coat added to the manually assembled (post coating) components that can be observed on the left side of the board photo. The conformal coating is solvent proof so will not be touched by ordinary solvents. An xacto knife and careful scraping of the coating off the pad is required to make solder adhere. Try it on one of the larger, less delicate pads so you don't further damage the board.
#26
That's NASTY STUFF. Larrt! Defcon One, EPA love triangle stuff.
NavLinear
#28
Larry,
We used to use chlorofluorocarbon (freon) and trichloroethane 111 to clean our printed circuit boards. The solvents would remove conformal coating quite well. We presently use a product named EnSolv - a vapor degreaser and cleaning solvent made by Enviro Tech International.
http://www.envirotechint.com/products/aerospace/
That green stuff Joe pointrd out on the left side of your photo sure looks like some sort of solder mask repair coating but I have seen coloration in conformal coating in the past. Some of the solder mask repair coatings are epoxy based so that could be tough to get off.
One other thought for a solvent would be acetone. Be careful with any of the solvents as some such as acetone can also remove component markings or damage the wrap on the electrolitics.
Good luck
#33
If you use the methylene chloride, do not use it anywhere indoors. It has more red alerts than just about any other solvent.
speakerman1
OZONE ALLEY MARS (Visitor)
Wasted Days and Wasted Nights
#34
I thought I had paint stripper. I didn't. Some strippers has it in them. My liver is probably so messed up from beer and MEK that it is a wonder it works. I forget what we used the tric for. We went to a water based primer and it would freeze up when we used Prevals so instead of water we used MEK. LOL Dried fast and didn't freeze. Oh we used tric to reactivate the 1300L glue when gluing deice boots on. Some of that stuff will eat surgical gloves right off your hands.
speakerman1
#40
It is getting there. I clean try to solder. Stuff weeps out of the board when I throw heat to it. So I heat and clean. The solder is starting to stick. Or should I say tring to stick. LOL Laughing a lot must be the fumes. LOLOLOLOL
